inducer/exducer measurements for TE60 and 61
Blazer406
Mechanical Engineer
Looking for the inducer/exducer measurements for a TE60 and 61. I have been looking trying to find some of these measurements.... they seem to be hidden fairly well inside google as well as the regular Turbo Buick boards..... I usually find what I am looking for... but have had little success this time.....
Thanks Patrick. It appears that the PT61 is not the same wheel sizes as the old school TE61? Both gnttype and the chart on turbobuicks.com suggest the old school TE61 had the same compressor wheel as the TE60.... just different exhaust wheels. On your chart, you list different inducer/exducer dimensions for the TE60/PT61. I assume the newer PT61 is using the new tech GT wheel comparable to the GT6152 that Limit sells? There is not alot of technical info (at least not near as much as I would expect) available on the net for the various compressor wheels and turbine wheels.... or shaft and housing (compressor and turbine) info. You have to take a piece from over here.... and one from over here.... and yada yada..... combine it all together to make anything of it.......
Yes the PT61 uses the Garrett GT35R compressor wheel. And has the Stage 5 T350 turbine wheel.
Hope this helps.
Patrick
