Info on razor's kit?
KyleH
I was referred to this site by someone I am purchasing a Novi 1000 for for my 1998 Lincoln Mark VIII. I will be running a stock pully with no intercooler on a stock motor, with a Wlbro 255 Hi Pressure pump, 80mm MAf, Dyno tune, and 42# green tops.
This is in florida so it gets hot....we really only have 2 seasons, Summer and January.
I was told to aska bout razor's kit. Got a link to it? I was thinking I would simply build my own to save some $$ (I am 17 and make $8/hr) but am not opposed to a well designed kit. Is his run off the MAF sensor or does it use manifold prssure to contorl the pump volume?
On the Fords, you can run it off the MAF. The current issue of Modified Mustangs has an article using my system on an late model Mustang.
In Florida too.. I feel your pain.. as long as it can be tuned.. its a non issue.
Call me, i'll walk you through your options.. done a ton of Mustangs.. no MK VIII's yet.
Wasn't aware that was your site. If you make a post about alky injection, thats what gets posted first. I will give you a call as soon as I can which will proably be monday as I work 10-6 tomorrow and then sunday I am picking up my supercharger in Palatka (I am in ORL so 2 hrs each way)
Unfortunetly your kits are quite a bit out of my price range. In fact the GN progressive kit is a lmost as much as I am paying for my Novi 1000 kit (not just the HU) :(
You do have a very reputable site kit and I hope you still don't mind me calling as most of the guys giving me methanol advice, have a/a intercoolers on thier mustangs :P
Think of a Mark VIII as a crappy intaked, cast cranked, slushboxed 1998 Cobra. Those are esetially the main motor differences. Not to mention that I have 3.07 gears :'( and 4100 ish lbs after the s/c and driver.
You get what you pay for..... Razor's kit is top notch..... just my opinion.... save your money.... then buy Razor's kit....you will be happy you did.
