Inj/FP Fuse and oil pressure switch
GrandmasTR
My car is currently blowing the Inj/FP Fuse at about 2000rpm+.
I did a seach found that you guys suggested checking the oil pressure switch. I checked and it was unplugged. Ah ha! But I've also read on the board that many of you run your cars with this plug just hanging. Also note my plug is melted to hell.
2 Qusetions:
Would my fuse be blowing because of the plug being unplugged or because its melted? Its been in bad shape for a while and running fine.
Where can I find a new rubber plug thing (female part with the 3 wires)?
TIA
If a bare end of the right wire on that thing hits grounded metal it will short out the fuse.
Tape it up securely with electrical tape and put a tie wrap over that big ball for testing.
Caspers should have that end you can splice on, maybe Kirban too.
