Im having an issue with a friends car im helping him fix the problem. This is an 87 setup by the way, so first of all it sounds like a cylinder isn't working. I started pulling plugs to see if there was spark in all cylinders one was very weak almost no spark i changed the coil pack ign module. Still gave the same symptom, i started pulling injector plugs to see if all injectors are working. One had no change in idle nor engine characteristic so i thought well it either has to be this injecor plug or injector. So i did not have a probe to check the injector, but i did have a multimeter. So i checked the injector plug and the plug wasn't receiving any voltage. Now behind the injector plug (wires that lead into plug) its receiving over 6 volts. I checked every other injector plug and they were only receiving half a volt .50-.61 volts and only that injector plug was giving me 6+ volts??? Any ideas? I cut the plug and im going to try to adapt another plug n there or i might just tell him to buy a caspers injector harness new.. I want to know if i should be looking elsewhere as well? My uncle told me it could have a bad ecm or a resistor that has been shorted. Need some assistance this car has been kicking are butt.
BTW the injector harness had a spliced wire to run a blackjack anti theft security alarm its running off the same plug thats giving me the issue im thinking the fellow who checked for injector pulse short circuited that plug or harness you think the ecm could also have been damaged?
