Jan 9, 2006 #1 C carrddine boost junky Joined Sep 11, 2005 Messages 360 what should static line pressure be with 42.5 lb inj...trying to get a solid answer...
Jan 9, 2006 #2 salvageV6 Daily Driver Joined May 25, 2001 Messages 20,996 There is no solid answer. Your chip manufacturer should tell you the baseline pressure. Usually it's between 40 and 45 psi. static measured, ie. hose off. I'd start with 42/43psi. and watch your scantools. Or contact the chipmaker and ask them.
Jan 9, 2006 #3 Jerryl Tall Unvaccinated Chinese Guy Joined Dec 14, 2004 Messages 9,643 salvageV6 said: There is no solid answer. Your chip manufacturer should tell you the baseline pressure. Click to expand... I am no expert but it is as stated by Salvage6. A solid answer would also imply a calibrated gauge, injector flow exactly to previous cars and matched, matched intake flow, etc. The chip maker will get you real close and you need to tune from there.
Jan 10, 2006 #4 C carrddine boost junky Joined Sep 11, 2005 Messages 360 thanks for the help ill start with 43 and go from there....
