Injector power wire problem
troyk
Just had the motor out & did a frame off restore, now I don't see 12v at the brown wire at the injector connector, no power at the pink/black wire at the main connector for the injectors. I do see power at the pink/black wire feeding the fuel pump relay, does this mean I have a bad wire in the wire harness or am I missing something?
If you have power on the fuel pump relay it sounds like you have a broken wire somewhere.
