Aug 17, 2009 #1 R redd222 New Member Joined Jun 7, 2008 Messages 59 ok i turn the engine over get no injector pulse untill i stop turning engine over then light comes on checked cam sensor getting spark?????????????? aLSO is there any way to make a hotwire kit 4 the injectors?
Aug 17, 2009 #2 pacecarta LOGGED OUT Staff member Joined Aug 1, 2003 Messages 9,610 yes you can hotwire the injectors , the pink blk stripe wire feeds 12v , try splicing 12v in temporaily
Aug 17, 2009 #3 R redd222 New Member Joined Jun 7, 2008 Messages 59 1 ok figured dat i already gave dat a shot still not working is there any reason why noid light flashes only when engine stops cranking
Aug 17, 2009 #4 B bison Moderator Staff member TurboBuick.Com Supporter! Joined Dec 19, 2005 Messages 18,053 Check for 7-9 volts at pin B on cam sensor connector with the key on and engine not running. Call caspers and order a hot wire harness from them
