injectors to service or not?
olds443
I have a stock motor and a set of Super Coupe injectors that I plan to install. They look real clean and each had fuel going through them. The car had 175K miles on it, not sure how many on the injectors.
Should I have these cleaned and serviced or just use as is?
I plan to upgrade later so they won't be on for very long, not sure it would be worth the extra cash if they work fine.
Opinions?
If they have been used, [and are out of the car now], there's a good chance the fuel in them has dried out and they can be stuck shut. I see this frequently w/ injectors I clean and flow. Some are so bad, they are junk, while others can be resurrected w/ a good smack w/ a plastic hammer, and then cleaned.:eek:
Hey sir, don't you also service them? What am I looking at ($) to have them cleaned,etc.? BTW they have been off the car for 2 weeks now.
