My buddy has a cyclone and it has an Accel gen6 and 40lb injectors. It was tuned and runnig great using a wide band 02. He was maxxed out on injector duty cycle so he bought a set of 50's. Here is the problem:
Runnining perfect before. Only thing changed is 50 lb injectors. Will idle and run fine with 30 to 35psi fuel pump pressure. will not start with fuel pump pressure at 35-42psi.
We are pretty sure the injectors are not opening with higher fuel pressure during start up. Can turn down pressure, start, then turn up pressure and it will run good from low into mid range(did not try any higher due to lack of tuning). tried messing with software tune(small and large adjustments) at higer fuel pressure=does not start.
old(40 lb) injectors all ohm out to 16ohms. New all ohm out to 12 ohms.
Are the drivers in the DFI having problems with the lower impedance(more current flowing)? Accell manual states they should work. Or could the injectors be sticking closed at higher fuel psi. I have heard of them sticking open, but never closed?
any info would be apreciated. Turbo6man
