injectors
MAXSIX
http://i574.photobucket.c
i would know if anybody use there v6 injectors on there ls swap ?
Other than coming up 2 short, I don't know why not.;)
The LS system is operated at 58psi, {4 bar}. So, the 3 bar rated injs will have a higher pph.
What size are the v sicks injs?
Depending on how the LS fuel rails are spaced, you may have to change the rail mount height.
The various LS intakes will have different rail configs.
i run Bosch 160lbs maybe just buying 2 more. i mesure the stock vs my 160lbs they have close lenght and same connector
