Hey guys,
I've had my F.A.S.T ECU in for about 2 years now, and I've never hooked up the inlet air temp sensor. Now I'm finally getting into the fine tuning, and I have it running perfect one day, then it seems when the outside air temp is cooler or hotter, it doesn't run the same. So, how important is the inlet air temp sensor, would it make a difference if it were plugged in. I have the enrichment vs. air temp table at zero all the way across. Does anyone have a ballpark figure on what I need to look for when adjusting this table. When I had the fuel map perfect, and I plugged in the air temp sensor, it went lean, so I unplugged it. But now, if it's going to make a difference, I'll redo the map.
Thanks in advance.
Thanks in advance.
