Inner fenders/wheel wells needed
wmerrell
I need both inner fenders/wheel wells for a 87 GN.
Anyone have the part number for these?
Inner fender wells
I have a pair from a 30,000 mi 87 GN,mint condition.$200.00 for the pair.Where are you from?Thanks.Tim.
I have both inner fender wells with the fender extension pieces from an 81 regal in very good condition. email me and I can send you some pictures billzgotpartz@yahoo.com I am located in Saint Louis, MO
only difference i saw was holes have to be drilled but the spot is there....i used my limited ones when i put turbo motor in not a problem
driver side is diffrent because the factory aircleaner box mounts on the frame and there is a big notch where it goes in the wheel well.na cars do not have this.
passenger side has a pair of lugs where a sensor mounts on the na car.turbo cars do not have this since the sensors mount on the inner fender.
will the na car ones work? yes. are they the same NO !
William you shipped out Thursday Should be there Tuesday.
84-5 Driver sides are different as well. No mount for the power steering bracket. Just because it states turbo does not mean it will be correct.
How ever the turbo 84-7 passengers are the same.
and from what i have found the passenger side is much harder to get since the cars are commonly crashed on that side and were cut for fender dumps or were melted by downpipes
