Input on trans coolers?
JP87GN
I need some input on trans coolers, I know heat is a issue for these tranny's so I'm going to install a good cooler.My questions are what cooler is everone running on the TB's and where are they mounting it? do most of you go through the stock cooler and the aftermarket one? any input is appreciated.
My recomendations would be a B&M super cooler
Northern Auto Parts---800-831-0884
Part # 70264---$52.99
Yes, the Super Cooler is a good one
Go through the stock cooler first, and then the B&M. It will be more efficient that way. It will scrub off some heat in the OE cooler, then a bunch more when it hits the B&M. :cool:
Couldn't you run the engine oil through the radiator cooler, and the ATF through an aftermarket one? I figured that way the oil could be warmed up a little easier, and I don't know if both rads are necessary for ATF.
