Install Time? - FP Hot Wire Kit
45 minutes its about right,with jacking up the car and all.Pretty easy to due.
30mns tops and get some extra zip ties I don't find a need to jack up the car tho just crawl under it and call it a day
i said 45 as i like to run the wire threw the frame and make it very stealth and clean like
Depends on how much/where the Becks is, in the fridge or cooler.If it's in the fridge in the house,account for traveling time.....:biggrin:
HAHA, sounds like my dad. Everytime we work on the car..you can another hour or so for beer time.
I ran mine under the drivers door sil with the factory wire harness. hard part was getting the wire thru the sealed connector inside the trunk to follow factory wire harness. About 4 hours.
Got it done today. Took about 40 minutes total including the consumption of a single Heineken. I ran it along the frame on the drivers side right with the fuel line. It's pretty stealth and looks like factory under the hood which is good for my GNX.
One thing I noticed quickly was that it raised my O2 volts from a dangerous 660-670 at WOT in 3rd, to a more comfortable 770-780 at WOT in 3rd. With a little tuning on the Scanmaster, I might even be able to raise my O2 voltage even higher and get to run a little more boost :cool: .
