Installed Extender, no lockup now?
Jon01
Over the winter while my car was torn apart to replace a dead cam I installed an Extender chip and new 50# injectors. Upon getting the car running, I noticed I didn't have any TCC lockup.
When I parked it last fall, it was working great, everytime at 45ish mph, r's dropped ~300.
I didn't do anything to the chip to turn it on, is there something I need to do to enable tcc lockup? I know there are several other features on the Extender chip that can be played with, is tcc lockup one of them?
Thanks for any help guys!
Jon
maybe you forgot to have that option on yours ...many run nlu
It should lockup OK during normal driving. You can adjust WOT lockup mph. Check switch under the column that it's adjusted properly and make sure the wire is hooked up on the transmission. Also possible your TCC lockup switch went bad and needs replaced. If all else fails setup a time with me and I can take a look at it for you.
Hey Chad!
The cruise works good, so I'd imagine the switch is adjusted ok.
It's still sitting at the painters, but once he's done with it I'm going to check that plug and see if it's getting power, then change the solenoid if it is.
Sheesh, I wasn't even driving it and something else broke! ;)
