6instantaneous6
- Jul 13, 2007
that sounds like its blowing out spark. what pulgs are you running and what is the gap at?
just checked....running acdelco 41-803 with .052 gap.
Did you check your IC hoses like Boost231 indicated? Always check your basics before you start swapping parts and spending $$.
Check IC hoses; vacuum lines; boost line y connector (swapped?); plug gaps; ensure plug wires are seated properly; follow positive cable to starter and ensure there is no exposure in the wire possibly shorting out under load; follow negative to ground; check tightness at battery posts; check fuel pump ground for tightness and no corrosion or overspray; check hotwire from alt to tank for any exposure. Also, make sure you have a clean fuel filter.
OBTW, did you port match the new turbo to the puck?
Hope any of this helps. Good luck.
Brian
checked plug wires and cleaned coil pack individually, cleaned and tightened ground from battery to block(right below turbo), also checked boost line y connector everything good (referencing gnttypes "quick references")
