There was an article on how to do it that I used. You gut the stock shifter leaving just the steel bottom plate. You fabricate a spacer out of aluminum to raise the rear portion of the shifter up. You have to cut the plastic out of the front section of the console as well as cutting the hole in the top shifter plate large. I have a mint gray console front section that was already modified for this if you dont want to cut your original. Email me if you are interested.
