Installing ALKY w/FAST - MAP question
Warp6
Mine since '92
When using FAST, you run the center GRAY wire of FAST MAP harness to the factory MAF sensor connector. Intallation of ALKY says connect PAC controller GREEN wire to the factory GREEN MAP wire (now GRAY with FAST).
My question: is it okay for ALKY and FAST MAP/MAF to share this same wire or do I connect it somewhere else?
That's exactly how I connected mine with my FAST. Just make sure that you have solid connections.
Yup.. no issue. Key on.. 1.6 volts DC is the number your looking for on the signal wire coming from the MAP.
Julio
