Installing Evolution Wastegate - Need Help
Hot Air
E85 and S.E./Carolinas Moderator
Staff member
Replacing DeltaGate on my ATR 3" DP with Evolution. Racegate had gasket on both the inlet and the outlet. Evo came with only 1 gasket and directions indicated to use it on the inlet only. Trouble is when I bolt down the inlet side of the Evo, I have a 0.075" gap between outlet and the downpipe connection. If I tighten down the bolts on outlet, I will put the wastegatge/downpipe in a real bind! What gives here?
Conrad Carter
Sounds like they might be getting cheep by not supplying a outlet side gasket.
If you were to make a gasket for the discharge side, would it take up the slack and bolt together without putting it into a bind? If so, I would look to make a gasket and glue it down and let it ride.
When I installed mine I just put it on the inlet side and it was fine. Im pretty sure I called Tnetics and they said it would be fine. I had mine dumped as well, I highly recommend it to scare the hell out of people:biggrin:
