Jan Larsson
- Nov 22, 2001
Got a set of new 42's from Racetronix, so took out my freshly powder coated fuelrail and installed the new injector harness from Caspers to make sure I have new clean and working parts.
Installed the new injectors (lubed the o-rings with the supplied silicon grease) in the fuel rail then installed the fuel rail (with the injectors) on the intake manifold.
Lined up all injectors and tried pushing them in place (all o-rings lubricated with the supplied silicon grease) but hard to push them down in the intake so ended up installing the bolts holding the fuel rail in place and torqued them down and that way the injectors got pushed in place looks like in the intake.
Is this enough or would I have to push them down further in the intake to make sure they wont leak?
