Installing new 9" PTC converter
Braciole
How many times is the converter suposed to click on the 2004r? It clicked twice but still doesnt look like its all the way in.
Mike
if it doesn't look all the way in its not. the converter should be so far back into the trans you can't see the shinney part of the neck of the converter. spin the tail shaft some while spining the converter clockwise and it will go. trust me you will know when it goes on.
3 clunks. Had a hard time getting mine to go the 3rd one and ended up putting the trans on end and the converter went right in. Of course this was done with a newly rebuilt trans that had no fluid in it. Worked for me.
You have any friends the are in the field that can come check it for you?
he has no friends :biggrin:
three clicks mike
and push it back , once on the engine push it back again and measure the distance from the flywheel , if its over 3/16" from mounting tabs to flywheel add shims to bring it under 3/16" , you want at least 1/8" pull out from trans but not more than 3/16"
and dont use the bolts to pull the trans onto the block , if it wont go figure out why , sometimes the converter pilot wont fit the crank and needs some sanding off of paint , not saying that dusty's are that way but its something to look out for, also a little dab of oil on the alignment dowels
Lol Thanks Pauly, Got it all straightened out tonite got alot done (Thanks Josh) need Turbo to come in, TT Chip, and Finishing porting Intake and Im ready to go!:biggrin:
