you need switched 12v for the electric oil gauges,,for that push a female non insulated spade terminal into one of the the ign ports at the fuse panel (theres 3 ports on left side and 1 port in upper center
for the lamp theres a gray and black wire with a rubber socket hanging under the radio pod that feeds the console indicator lamp with buckets (or ashtray with bench) that can be used for the gauge illumination .. black is ground and grey is lamps (the dash dimmer controls brightness .. or if youperfer run a female spade wire to the "lmps" port at the fuseblock and run the ground to the 10mm grounding bolt at the dash (to the right of the driver courtesy lamp under the dash)
