Installing the pressure module
Bobtempest
Moderator
Staff member
The grey wire coming from the pressure module connects to the grey wire coming out of the PAC controller correct? Or does it just splice into the grey wire coming from the PAC? In other words you must cut the grey wire coming from the PAC and connect it with the grey wire from the module.
Thanks,
Rob Hinson
Gray to gray.. nothing else. Discard old LED setup.
Thicker brown to pump shielded cable ie. bare wire.
Rest is easy :)
RAZOR,,you just sent me a new pump,,i assume the little black box is the pressure module ,what does it do??
Read the literature that comes with it.
Its a retrofit on older kits bringing it current. Now you have a way of knowing the system is not only activating, but making pressure.
I do not want to get into specific details on line about this. If you have specific questions, please pick up the phone and call me.
Julio
Thanks man. I went ahead and went with my gut feeling and installed it correct. Works flawless. Superior product.
