I have my Te-44 turbo off,exhaust manifold off,I was wondering what would be the best way to install the turbo in order knowing that I am going to use the Ultra copper for turbo to exhaust manifold,since both are off could i just install the turbo on the pipe and just torque it down, then bolt it to the crossover? or should i just bolt the exhaust manifold to the crossover then install the turbo???I want to make sure a good seal is made so I don't want to redo the turbo install because it was leaking before with a junky copper gasket.As far as the ultra Copper is it true that too much is not good and just a simple bead around the bolt holes and around the turbo to exhaust manifold surface is better??Does a little bead of Ultra sillicone make for a better seal??? Thanks for any replies!!
