Been awhile since I did an a 87 GN intake gasket so I have a quick question. Do you apply a thin coat of RTV to the front and back side of the stock "steel" intake gasket or just put on dry? I think I recall applying RTV around the water ports only. Correct me if I am wrong though.. By the way they are stock heads and intake. However I do remember using the rubber strips and dabbing the the corners with some RTV. A brief refresher is needed if anyone can help. Thanks!!
