I am going to use the Felpro 1200's for my BGC intake. I am also going to use the stock metal intake gasket and cut off the intake port section on each side, so that I can use the 1200's. Then use the valley pan from the one that I cut up to keep oil off the bottom of the intake. I got this idea from searching the archives on here. (thanks to whomever) Also did you modify your water ports on your BGC intake, the ports are too small? This will help keep your H2O temps down (I have pics of how I did mine if you need them.
