Intake Manifold?
TURBO2
My intake manifold has two broken bolt holes where the upper plenum attaches. I've been searching for a new one but the only one I can find that actually fits is the Champion ported intake for $1,300 but all sellers state that my GOOD core must be sent in first before they will even send one. Are there any stock ones still available with no core needed?
You can try NATS?
Aren’t there places that repair them? Somebody here would know that. Are you sure yours can’t be repaired? Sure it’s considered “not good” by guys that want core?
Good luck.
You can try NATS?
Good luck.
One of the bolt holes that broke is the internal one in the back. I'm not sure if I would trust any weld job on that one. If it broke loose, bye bye engine.
Lemme see what I can dig up. I think I have one I bought off a board memeber in my stash.
I have a complete stock manifold, plenum, and throttle body. I'm happy to send pics via PM if you want
I won't unpack them until I know you are seriously interested in purchacing the whole kit and kaboodle.
I will not separate them.
Seems I have the only part(s) in our galaxy that you want, at this point. That's just a fact.
PM me, let's talk.
Honestly, I'm not sure I want to let go of this packge, but a Buick Brother in need, is just that.
Many folks here know me, I don't jack people around.
Here's a taste...
Turbo2, I know this is an older post, do you still have the intake with the broken bolts? If so, would you be willing to sell it? Thanks.
I'm still using it. I had to setup a clamping device to be able to keep using it. No way am I spending the ridiculous amount to replace it when just about every other engine made you can replace it for next to nothing.
I wouldn't be afraid of having it repaired if I'm visualizing the broken area correctly.
If you were to send your core in they machine out the EGR tower and tig weld on the inside anyway
Too much money to spend right now. I took it out for a ride late Fall and the #5 cylinder stopped firing. I have to look into that come Springtime before anything else.
