Intake pop?
turbokar87
Installed a new cam sensor fixed some cracked vac lines. Went to drive it And to see how she felt. Started popping from the intake and she wouldn't pass like 2500 rpms. Tps is almost perfect. No codes coming up on the scan master. I don't want to go back to the shop if this is something I can do ?
Start car then disconnect Cam Sensor. If it runs properly you'll know the CA is not set properly.
Reconnect CA before starting car again.
