Intake Survey
ikle
Whats everyone running on their street/strip car these day's. Ram Air, Cold Air Intake, or just a simple K&N filter attached to the MAF sensor and what gains have you seen ? Thanks for participating, Kyle.
Also what size MAF pipe, 3",3.5" or 4" Thanks again, Kyle.
Ok I'll start it off, I am running Marks Big Mouth cold air intake with a LS1 MAF sensor with Marks 3" MAF pipe.
Nothing extravagant - just ran my first run in the 10's. I haven't made a run since installing the 2 step so I hope to improve my 60 by taking advantage of the timing retard feature to build boost on the line. My 10.95 was with a 1.78 60.
Stock MAF pipe, old ATR filter housing with Chevy truck paper air filter....running 10.90's@125+
hello; Tin Man CAI, 3.5' MAF, 3' MAF pipe. No speed time but the newer MAF with the trasnslater it smoothed things out.
IBBY
3" and 3.5"MAF on most of the local cars with an open element under the hood.
4" RJC MAF pipe with no MAF sensor, Huffman's cold air kit with Big Mouth filter and KB air dam channeling air flow at the filter.
Factory setup I had a 3" homegrown cold air out by the bumper with a K&N cone and factory, LT and LS MAF's (changed through the years). Always bugged me seeing high ATS readings with filter in engine bay/underhood or flashing Hot on the ats screen of the SM.
Once it was out by the bumper it was near AMB.
Con out by the bumper on a DD is it gets dirty quick
tin man cai ,3.5 zr1 corvet maf , 3 g body maf pipe but will be upgrading to 4 inch maf pipe when turbo gets upgraded
