Intercooler cleaning...
86TType
Slick 86 T-type
I got my stock intercooler off and i was wondering what could i clean the inside of it out with?
I always had best luck with Castrol Super Clean in the purple bottle and water.
Pour half the bottle into the intercooler, swish it around really good. Let sit for 20-30 minutes to help breakup caked up oil residue. Then, turn on the hose and let it run in one neck until the junk starts pouring out the other end. EPA peeps please turn your head and look away.
Pour the rest of the Super clean into the intercooler on the other neck. Swish it around for awhile. Let it sit for another 20-30 minutes. Fill that neck with water until it starts pouring out the other neck. Now, with the intercooler completely empty, I fill it with water, repeat the swish procedure, dump, fill again, dump, fill again and dump. I keep doing this until the water is clear. It might take awhile before the water really gets clear, but this is why it's important to let the super clean work it's magic. Once you are satisfied with the cleanliness, turn the intercooler upside down so that the necks can drain out and tilt the intercooler at an angle. Just let gravity be your friend to help drain it out. I always let mine sit for about 4-6 hours. After which time I shake the intercooler as best I can. No air compressor back in the day. If you have one, you can blow it out pretty good using a towel and sealing the nozzle with the towel and your hands.
That's it, that's how I've been doing it for years. Works everytime.
HTH
Patrick
You can also dry it out by hooking your shop vac to it if the vac has the blowing option.:) Just duct tape the hose to the inlet and let er rip.
I use 1 gal of gasoline
1-i poor the gas into the IC let it sit a few minutes
2-i slosh it around
3-poor out the gasoline
4-let sit up side down for a few more minutes to make sure it all comes out.
5-install it and go.
With my old leaking turbo I became a pro at doing this.:mad:
Every other week I would get at least 1.5 quarts of oil out of it before I put the gasoline in it. :eek: It was so bad that I just put it upside down for about an hour or so drained the oil out and just put it back on.:redface:
