intercooler for 85 hot air car
Good luck finding one. Spearco made one years ago, which is what I have. They don't make them anymore and I haven't seen many available on the forum. It's actually not too difficult to make yourself. You can purchase any front mount cooler and then fab the pipes yourself. I have the fabrication guide that I could send you. You'll have to reclock your turbo, which is fairly simple. Grind down the fins on your intake (to make room for the turbo so it
won't hit your hood), machine your actuator plate, and then fabricate your pipes. I also suggest you relocate your throttle body closer to the intake, though this is not mandatory, your car will have less lag and better drivability.
If you look into all the picks under the hot air section, you'll see all different types of IC set ups. Be careful not to spend too much on this set up, the HP
gain may not offset the cost. You can realize more HP gains by other modifications. What are your goals? what have you done to your car already?
i was wondering if you could send me the fab guide for building a intercooler
