SSedan good point, so in your opinion using the stock oil cooler to cool the trans fluid wouldn't cool any better than using the stock tranny cooler ? Then if I incorporate -6AN lines the fluid would be moving faster in more volume and do to the trans fluid beinng thinner than oil wouldn't cool properly ? What I am trying to accomplish is building a trans cooling system that would handle anything from bumper to bumper traffic to drag racing. Right now I am just running a external cooler with the stock D5 but I am upgrading the TC to a PTC 10" lockup, so I figure I need to upgrade the trans cooling system as well. The reason for me to want to plumb the lines into the radiator is my car runs at 165-170 degrees consistently which they say is optimal temp for the tranny then into my external cooler. What do you think, should I just keep the factor lines, run them through the stock tranny cooler, then into my external cooler and call it a day. Thanks for your help, it's greatly appreciated, ikle.
