Intrepid Fan Mounting?
landon86gn
I saw on here that some people were installing dodge Intrepid Rad. fans in the GN's I just so happened to have an old ped sitting out back and stole the rad fan setup out of it to put down in my 86 GN, I was hoping someone could help with the wiring and mounting procedures for this upgrade!
Thanks for all help in advance!
Landon
Wiring: Racetronix - Turbo Buick Dual Circuit Fan Harness
I used 2 battery clip style hold downs flipped up and bolted to the bottom radiatior fan mounting holes. Slide the fans into it and fabbed up 2 upper bracketes out of sheet metal to hold the top on. Needed to do alittle shaving of the fan shroud to make it more flush.
