Irwindale This Thurs? 11-9-06
I want to see Nordy yankin the front wheels :D
Petesgn come next thursday night.. Bob (TT V8) and i are trying to fit the new 29.5 slicks under the rear next week.. so hopefully this will help my 60ft's increase..
Yea a, right....
I'll be sure and relay that to her,
see if you ever get out of the house again! :tongue:
Damn wife... i should let her walk home from the airport :)
Nordy are you looking to spend time sleeping with the dogs, becarefull the wifey may read this board, and that be it for you, but don't worry your welcome to use my couch for a while if that happens.:biggrin:
wiked
No new best on his last Run something went south with the trannie, i am sure he will come in and explain.
Well I was able to make 2 & 1/4 passes. I have a new 8point Cage, GTQ67, and C16 fuel. I turn off the alky set the timing to 26.
First pass: I didn't change anything from my alky tune 7.4 @ 93mph 25psi boost and 769o2's no knock w/1.68 60ft
Second pass: First I leaned out 1st & 2nd gear on the fuel, and added 2psi fuel overall 1,2,3,4th gear on the chip 7.26@ 95.8 mph 25psi boost and ran lean 756 o2 no knock w/ 1.63 60ft
Third Pass: Added 3psi on the fuel psi regulator now 45psi, added a little fuel too 1st & 2nd Launched Hard w/ 1.59 60ft @ 20psi on the trans brake pulled the wheels off about 2'' then hung in 2nd gear hit the rev lim and popped. :frown:
I think the spring in the valve body is stuck. It's causing my shifts to hang. I pulled on the TV cable and theirs about a half inch of play till I feel any sort of spring tension.
I'LL BE BACK NEXT THURSDAY!!!;)
I just need to get this new tune right with the C16.:D
I Sucked Tonight :(
First Run: Ran really lean EGT 1668 :eek:
Second Run: Damn foot slipped off the gas during 12psi transbrake launch
F*@#ing stupid! After an 1Hour 30min of waiting! :mad: still
ran 95mph :D EGT 1616 still lean.
I sure hope AZ is ready for my dumb a$$ LOL
