Is a plasma moly ring better than a "moly" ?
Walt03
For the turbo motor, some folks say to go with a moly cast iron ring others say plasma moly cast iron. What's the difference for performance, wear and break in?
If my cylinders are set up with a 400 grit hone ( 45 hatch pattern)and finished with a couple swipes which a plateau hone, which of the two above is the best ring to use???
What's the best brand of rings??
Thx
I have run everything from Hastings castiron,Speedpro Plasmolly to Totalseal gapless never had a ring problem.On my GN I have Hastings $33.00 rings on it and dont have any pressure problems,leaking cylinders.That's at 10.28@124mph.Just my 2cents.hope this helps.Take Care,AL.
