They are just as good as any other production block. They are all equally weak and fail in the main webbing. Not the lifter area. Therefore a 109 isnt any stronger regardless of what scot w. has posted. If we start seeing blocks failing in the lifter area he may be onto something though
. I would have no problem running any early block from 83 up instead of a 109. Only problem would be having to buy another girdle if you had a 14 bolt block. The 140 is a 20 bolt though and has a slightly taller deck than the 109. My stage 2 is cast like an early block in the lifter area and id bet my balls its much stronger than any production block. Based on scot w's post im a little nervous to run my stage 2 and might just scrap it and look for a 109.
NOT!
