Boost231, if you dont mind me asking, what stall converter does your car have? I know it is basically combo specific, but I'm just curious?
Thanks for the input guys,
Jerry jr.
ok, let me see here. I will give you my opinion for what its worth. this is just knowing alittle about your car and the setup it has. also this will be looking at your data log's and what i see. reminder its just my .02
Frist thing TPS. yours is reading .48 at idle, thats the max it should be i would bump it down. i like to set mine at .44 closed throttle. For WOT, your at 4.38, thats not bad but i would bump it up some. i like to see 4.50, this a good safe place for it to be.
IAT-- Where is the sensor at? filter from what i can see.
A/F ratio- you really need to get a WB sensor on there. Tuning with 02's and even egt's at 30psi is crazy IMOP
Shift's Points/Tranny- Your trans looks ok. the shifts are not super fast but they are good, no real slipping that i can see. also you are getting good RPM drop 600-800 is good. One thing i see however is why are you letting it shift into OD????
leave it in 3rd. Also IMOP with your 208/208 cam and ported heads you can rev that motor out more. there isnt really anything easy to make the shift points higher at this point in time but you can do it. i would probley shift your car around 5300-5500. so with that being said leave the car in D and let it rev out on the top end. im sure that car will pull good in the upper RPM's. your losing alot letting it shift into OD and 87 MPH @ 4500 RPM's.
MAF- looks good for the track but how is it on the street? it took to 23psi of boost before it would max at 255. IMOP it should be maxing out alot lower then that.
Coolant temp- just looked at more logs and more data. I hope you don't have a head gasket issue. I would really look into it
241 deg. WOW . i dont like what i see for knock and i do believe the knock is real. i also believe thats why your temps are hitting 241
Injector duty cycle- looks good. if you get up in the 90's just add more alky
Exhaust Gas Temp- your is at 1450. thats safe. when we use to tune for Exhaust temp we would shoot for 1600's. now things might have change. But like i said i hate tuning with just EGT's becuase its effected in alot of different ways.
Boost Pressure- IMOP your Boost is way to high as of right now. you need to IMOP slowly bring the boost up more and more. start at 18 or so and slowly work your way up. it has taken me several track visits to get mine to 25. i bring mine up in slow increase to make sure everything is good. last thing i want to do is hurt my new motor by rushing things. so IMOP TURN THE BOOST DOWN :biggrin:
Knock-- even though you have c16 that doesnt mean its going to stop knock or allow you to run 30 psi. your knock doesn't start till around 27psi of boost. now from what i looks like its real. how can we tell. turn the boost down to 22and run it or hell even 20. also with the way the timing is set in this chip i wouldn't be running no 30 psi at 25-26deg of advance.
you need to start lower on the boost and timing and work your way up. find out if this is false or true knock. IMOP i believe its true and hopefully you havent hurt the motor.
Bat- battery looks good.
02's- they look good but we will never know the true a/f without a WB sensor. your o2's are around 770 and from some of the data i have goten on my car thats around 10.00-10.30's but its hard to say as i have got 815 on other passes where the true a/f is 10.00-10.20's. so you can see how 02's suck.
ok with all that being said this is what i would do, you need to check to see if the motor is hurt, headgasket?
i would also lower the boost and next time out lower the 3rd gear timing to around 21 or so max. i would maybe bump the 1st gear timing down to around 24 from 26.
your spool up issue. are you sure you dont have any exhaust leaks. just want to make sure no cracks in headers or anything. there is no reason that converter shouldn't spool the turbo you have.
humm, not sure what else to put. lets go from there and see what others have to say. im not happy with what i see
O and for your question about my car and converter. well the converter i have is a PTS billet 9x11 2800-3000 flash lockup unit. now this converter has been great for me from 13's to high 11's. spool my 54 super fast and locks hard. now that i have changed a few things with my setup :wink: im changing it out.
o and about timing. i know you have an intercooler and all and the intercooled cars can get away with more timing i wouldn't push your setup to hard with timing. slowly work your way up and see what your car likes. i was running 19deg in 3rd for a long time since my IAT in the intake are 200+ deg. i just bumped it up to 21deg and the car reacted well. this is with the boost at 23 or 24 psi (cant remember). i will now keep adding more boost till i get to my target of 30 or so
. once i do this i will probley play with the timing more. this is just to give you an idea on how low my timing is. my low gear timing is at 21.5 deg. so you can see im running low timing in low gears as well. basicly 21 to 21.5 deg the whole way down. now with that being said and how fast my car is running now just think once i go all out and bump the timing and boost up, what she will run
hope this helps some
Brent
