Is there a such thing as "too much fuel pressure"?
"Turbo-T"
V6 on steroids
Just curious, when I installed my new adjustable fuel pressure regulator from Accufab, I set the static PSI at 46 with the vacuum/boost line off. I have #36 lb blue top injectors and push around 14-15 PSI boost.
This isn't too much pressure is it?
Should I leave it as is? Or back it down?
Thanks.
If you are running a turbo tweak chip, i see it is listed in your signature you should contact Eric and ask him what he suggests to set the pressure at.
I personally think 46 psi static would be to high.
I just looked on the turbo tweak website and it says he calibrates his chips at 43 psi.
Here is the link for turbo tweak.
TurboTweak Home
Eric does suggest 43 with vac line off. My car drops to 37-38 with vac line connected.
