Is there any grounds on the back of head?
87gn-newbee
I do not see any but I thought there was when I took the DS head off. I know there are 2 on the back of the PS and 1 on the front.
What gets bolted to the back of the head on the DS side? anything
Dan
yea, theres a ground strap coming from the fire wall. that bolts to the back of the head on the drivers side.jusat got done doing that.:D
I thought that ground on the firewall grounded thru the transmission to motor bolt on the drivers side??? you know, one of the bolts that holds the trans to the motor... on the drivers side...
you can relocate the pass side PITA grounds to one of the intake bolts, just make one of the pass side intake bolts at the back of the intake into a stud, and ground them out there, since they will go into the head anyway, that makes a good ground but alot easier to get to in the future
BW
Originally posted by 87gn-newbee
I.......What gets bolted to the back of the head on the DS side? anything? .....Dan
There is a clamp for the TV cable originally attached to the back of the DS head. Don't know why anyone would replace it once removed?
My guess it was there for assembly line reasons.
