Is this a factory or aftermarket sunroof?
1987-NP
The factory CF5 has a single chrome switch that's the same style as the door window switches, along with an emergency manual crank bolt that's covered by a plastic button cap. Typically in the glove box, you would find a small manila envelope that contains the hex key wrench. You'd use this to manually crank the moonroof closed in case the battery died with it open. As well as having mirror tint.
Aftermarket sunroof typically has the black rocker switch and very little detail trim work around the head liner's hole.
- Patrick
also too squared off at the corners of the glass.
