would just like to know if i got this right before i get in to it .
remove both front brake out lines from the prop valve and screw both of them in to opposing ends of a "T", make a line that will go from the last port in the "T" to the outlet on the line lock. then run a line from one of the open ports on the prop valve to the inlet port on the line lock, plug all left over open ports bleed the system wire it up and go do a burn out !
