Is this false advertiseing
Its a HA wannabe. Lol
Seriously . . . That car may have been re-vin'd. It has the correct front spoiler, vacuum hose sticker and hood pad for a HA . . Could someone want a HA bad enough to change the belts, ps pump, ac system, engine wiring, turbo and ps side header just to have a HA car?
IMO if its re-vin'd its false advertising because its a vin 9 car.
sometimes you use the parts you have access to when putting a car together..
i just looked at my 84 T Type out in the garage, and the vacuum hose sticker isn't where it is located on this particular car, which has it in the same place as any engine bay images of 87 GNs that google pulled up for me... i think mine was on the stock radiator shroud that hasn't been on the car for over a decade, because it's nowhere to be found under the hood..
The VIN is stamped on the frame if you really wanted to find out what it is. VIN was also stamped on the block and trans. Or the obvious Trunk Lid sticker he omitted. Powermasters were installed on mid to late 85 cars so that means nothing. Either way without a Trunk ID, window sticker, or build sheets you can't assume anything.
frames and trunklids can be swapped, so any VIN on them doesn't really mean anything...
the little details (rear brake light and matching rear defogger grid, powermaster brake booster, heater core inlet and outlet angle, vacuum hose sticker placement, a few other little things) point to it being an 86 or 87 with the 84-85 turbo setup in it..
Right and if the VINs don't match on everything that I mentioned then you know the car isn't what it's advertised as. No paperwork means NOTHING can be verified.
