In order to clear my PS turbo I had to install a alt bracket that positioned the alt higher than you would normally have it . causing the 6 rib serp belt to have alot less contact area on the water pump pulley . take notice in the pic .. is there enough belt contact on the water pump pulley as to not cause any problems ? the first thing my brother said when he saw the setup was "is there enough belt on that pulley" ? so...that got me thinking .
