Is this normal please help???
gn_steve
boosted canadian
Hi guys and gals here are the milivolts reading while on the highway at 65 mph are these normal and if not what can be causing my issue???pump is new 345 e85 pump tank is full all lines are new pressure set at 43psi vac line off!!
Sorry for the shaking of the camera roads are bad here!
They look ok. O2 volts at a 65 mph cruise are not all that important as there is not much load on the engine. You want to take your readings at WOT and monitor knock retard along with it. The O2 volts are supposed to go up and down at cruise
That's normal. You are in closed loop at light load. Your O2's are supposed to cycle.
