is this vaccum bosster correct, please help!!
rayboy231
just worked on my brakes, i replaced front calipers, rear wheel cylinder and two stainless brake lines, also i bought a kit to convert the pm to vaccum brakes. i also changed the master cylinder out of an 86 monti ss. the problem is now that the car stops but the brake pedal still goes 1/2 way to the floor before it gets hard, i bleed the brakes numerous times no air. is this vaccum booster correct?
looks like it is.I have the same one on my ride.I needed a moroso vaccume can and a vaccume block on top of the dog house to work good.
yes sir brake pedal also.keep the p/m parts you might want to go the hydroboost route.thinking of going that way myself.
