- Jun 18, 2001
Took the car out this weekend and at one point the drivers side was pulling when the brakes were applied but then things were OK after a couple of additional stops. Things are back to normal now, any ideas?
Did you bed the pads in after they were installed? Did one side get wet? Do the calipers slide freely on the pins? Have you checked for excessive bearing play in the front (can cause pad knockback)?
