Anybody have a copy of the instruction info sheet for JE Pistons (#131556/.020") that you could fax or send via email to me . it would be VERY much appreciated .many thanks .
maybe I should of updated this post . that's what I ended up doing after all using the neighours fax machine . so if anybody needs a copy I have one available . . thanks .
a odd thing on this JE piston install/spec sheet is that there is no reference to piston directional postion . leading me to believe these pistons are a symmetrical config piston and they can be installed either way ."and we all know" that there are no valve reliefs cut into these pistons to show direction as well .
Yup they go in either way, but the spec is .004 wall clearance, but i noticed alot of scuffing the skirts on my stock block, next motor i am going .005
Originally posted by norbs Yup they go in either way, but the spec is .004 wall clearance, but i noticed alot of scuffing the skirts on my stock block, next motor i am going .005
