I would not spend the money for coating on an unrepaired set of headers. Been there done that. I currently have a d-side header crack. When the header was coated it was unused brand spankin' new. I would say use a d-side that has been cracked and then repaired properly and you will have better luck. You should be fine with the p-side one though.
HTH
