Just installed a GReddy PRofec B-spec ii boost controller
tbirdv6
I've had ATR, Q boost, & RJC-all being manual
But this electronic one is the BOMB
First, very easy install-pretty much plug n play
Records highest boost
Warns you of your boost limits you set & than reduces boost by % you set
Allows to to have 2 different settings of boost(hi/lo) so you can flip/flop in a nano second
Spool-up is INCREDIBLE, you can set it up as fast or as slow as you want
Its small/compact-it lights-up & no more adjusting under the hood.
I purchased this from a member on this board for $200
Did the install today w/Razor(Julio) aka www.alkycontrol.com
Now I know why he uses this unit-wish I found out sooner-would have saved a motor
I highly recommend this to everyone, check Ebay
FRED
I love mine also. I have the wireless remote switch on the steering wheel and can switch from 14.5 # boost to 24# with a touch of a button.
Rock steady Boost. ANd you can play with the spool up characteristics with a touch of your fingers right from the drivers seat. It is the perfect compliment to a Trans + and Extender.
is that one of the stupid rice looking ones with the super bright blue lights and all the other crap or something that looks good enough to have in our cars?
i've looked at some of them, really liked the features but didn't do it because it looked like rice stuff.
I don't think its rice at all. I love mine, and I have friends with other turbo cars that use them as well.
The thing flat rocks! Only thing I wish it did was allow you to set boost as a psi instead of a duty cycle for the solenoid.
Interesting. I'll have to see how my BstC holds up when I ugrade my turbo this year. Seems to work ok for now...
Does that system come with a solenoid?
Does it work with the stock wastegate system?
yeah give us the specs and any pics of install if possible... im pretty interested in something like this.. the old manual just isnt cutting it anymore.. plus its scary dangerous staring at the boost guage while turning my little knob up... would much rather flip a switch and focus on more important things... like the road... and the other guy.... hopefully behind me :cool:
It does come with a solenoid, and is compatable with the stock wastegate. Truely, a quality piece, which has it's own internal 3 bar---Taffy sells these. Brian
MORE INFO
yes yes we all need more info i was thinking of one of those and maybe a turbo timer has anyone installed one either was staying away because of rice rockets:confused: :confused: :confused: :confused:
I thought the same thing as being rice of the name GReddy, but that isn't the case-
The functuality of the unit is so necessary for our cars-its all about controlling boost & it does it so well right in the cockpit of your car
The solenoid sits right were the stock one sits (valve cover, they both sit together nicely)
The two vaccuum hoses (wastegate & turbo) connects to the 2 ports of the solenoid, solenoid has a plug n play harness which is fed thru firewall to unit.
I mounted the unit right under the dash w/velcro
After owning a few turbo buicks-This unit is a MUST
It will prevent over boost, controll boost & spooling
Need I say more??
FRED
PS- You need to get over this "rice" thing
I'm 50 yrs. young & the last thing i would do is add rice!
Hey quit giving secrets away..
:D
Almost in the sliced bread category ;)
