K-1 rod bolt torque spec
chasmat2316
I have K-1 rods with ARP 2000 rod bolts, I know they say to torque 30lbs & then go 60 degs- but has anyone come up with a torque spec that is very close? I
Using the rod bolt stretch method as outlined on the K1 instruction sheet it took between 90-100 ft/lbs to reach the specified stretch. I was surprised how much it took but thats why you need to either use the angle or the stretch method, using a specified torque is inaccurate.
Mike
86 GN
Was that with moly , oil, or dry? That is a lot for a 7/16 thread. I have the old H-beam rods that ATR sold with the same ARP fasteners as the late K1's and the torque spec is around 70 ft. lbs with moly. A stretch gauge is fairly cheap and worth having if you are assembling engines. Id get one for the accuracy they provide.
That was with the lube that came with the rods, 7/16" x 1.550" under the head length ARP 2000, .0056" to .0060" stretch.
Mike
86 GN
